Thread Status:
  1. CoreyPerez
    All,
    I have been getting a "Clunking" noise/feeling under my feet and found that my upper control arm is sliding to the mount both left and right (PS to DS). Its obvious that the control arm is the moving item. I'm curious if this is a problem with the bushing or the control arm. Just so I can get the right part ordered. Money is tight having just transfered to a different branch of the military so I can't do my normal overkill replace it all approach.
    Oh, and it appears that the bushing is 100% intact and not damaged, other than the components are not bound together...
    Thanks,
    Corey
    CoreyPerez , May 5, 2008
    #1
  2. RStankevitz
    we had a gasser that was doing that and i just spoted it together with my mig welder? it was fine for the next 3 years
    RStankevitz , May 5, 2008
    #2
  3. AKAMAC
    Is the steel sleeve moving in the arm or is the bushing moving in the sleeve?
    AKAMAC , May 5, 2008
    #3
  4. CoreyPerez
    The bushing looks 100% intact and is not moving, the actual control arm is sliding on the metal outter surface of the bushing... (Unless this is a metal inner surface of the control arm... )
    Thanks
    Corey
    #4
  5. Cummins Thunder TDR MEMBER
    Cummins Thunder , May 5, 2008
    #5
Loading...
Similar Threads - bad control arm Forum Date
Bad drive train vibration fix 2nd Generation Ram Forum Archive Aug 28, 2021
bad headlight switch 2nd Generation Ram Forum Archive Aug 8, 2021
Which part is bad 2nd Generation Ram Forum Archive Feb 10, 2020
Thread Status:
Share This Page
