Thread Status:
  1. Mark31 TDR MEMBER
    My money pit needs a new power steering pump and it looks like Mopar has stopped making them. Zero confidence in the only rebuilder I know about. Anyone know where I might find a new one for my 04?
    Mark31 , Apr 19, 2023
    #1
  2. Darkbloodmon TDR MEMBER
    Mopar flavored? No. I am using this Cardone one, albeit I have to send it back since its leaking out the lower fitting going into the pump, it could be a one off issue, but I've been driving on it for a year or two while leaking no issues besides the trail of blood. It does have a life time warranty and is a new unit.
    upload_2023-4-19_11-20-57.png #ad
    If you find a better one let me know, I heard you can retrofit or drop in the later model power steering pumps with some light modification, I'd be interested if I could snag one off a parts truck else I'll just stick with this one.
    Darkbloodmon , Apr 19, 2023
    #2
  3. Ozymandias TDR MEMBER
    I switched to the ZF type pump when mine went out, easy change.
    Got a Cardone NEW from Rockauto and the Reservoir.
    Works flawless for the last 2 years.
    Mopar stopped to make the ZFs anymore, so my best bet was a new Cardone - Rebuild now way for me.
    Ozymandias , Apr 19, 2023
    #3
    CVR222NV and Darkbloodmon like this.
  4. CVR222NV TDR MEMBER
    I had already upgraded all my steering components to the 2008+ except the pump and although it never leaked it would build up enough pressure to blow off the cap so I replaced it with a used pump and hoses I found at my Dodge pick a part source. It was off a truck with only 60,000 miles. I have had no further issues.
    CVR222NV , Apr 20, 2023
    #4
  5. GSellers TDR MEMBER
    Just changed mine new Cardone from Rockauto
    make sure you buy the pulley. I didn't my old pulley came off fine and was in good shape
    but the new Cardone has a bigger shaft than the original one. It put a stop to my Saturday project
    I Considered taking to a machine shop $75hr.
    but the cost for the work was more than a new one from Rockauto
    GSellers , Apr 20, 2023
    #5
  6. endoscott
    Man, you got a machine shop that is only $75 an hour?
    endoscott , Apr 20, 2023
    #6
Loading...
Similar Threads - Mopar power steering Forum Date
Mopar/Amp Research power steps and Isspro gauges being installed! 3rd Generation Ram Forum (NO engine/transmission topics) Archive Oct 10, 2006
What antifreeze is compatible with the Mopar that it came with? 3rd Generation Ram Forum (NO engine/transmission topics) Archive Dec 27, 2022
Need a Part # for Mopar PREMIUM brake pads 3rd Generation Ram Forum (NO engine/transmission topics) Archive Dec 13, 2022
Thread Status:
Share This Page
