1. garylmoore
    What is the proper way of locking the engine to torque the injection pump timing gear nut? The recommendation I read was 165 ft lbs.
    I've done this a number of times before and I believe I stuck a rag under the alternator pulley, but it seems there has to be a better way.
    The injection pump is installed and the keyway is lined up with the mark on the timing cover.
    Thanks
    garylmoore , Jun 22, 2024
    #1
  2. GAmes TDR MEMBER
  3. Joseph Donnelly
    I also use a barring tool. That is way too much torque; I don't recall the correct value but it is somewhere around 100-120 ft b.
    Joseph Donnelly , Jun 22, 2024
    #3
    brucejohnson likes this.
  4. BigPapa TDR MEMBER
    AllData says 125 ft/lbs.
    BigPapa , Jun 22, 2024
    #4
    brucejohnson and Michaelsloft like this.
  5. garylmoore
    I have never used a barring tool. I was under the impression it did not lock the flywheel in place, that it only allowed you to turn it.
    Do I need a helper to prevent the barring tool from moving while I torque the nut? Thanks.
    #5
  6. GAmes TDR MEMBER
    No. Just slide it in the hole. It pretty much jams the flywheel/flex plate teeth. At least on mine it does.
    GAmes , Jun 22, 2024
    #6
  7. BigPapa TDR MEMBER
    With the barring tool in place, you have a gear with @ 200 teeth trying to turn a gear with 8 teeth. It will hold the flywheel.
    #7
    Ozymandias likes this.
  8. garylmoore
    Thanks to all that replied.. that is what I was looking for.. Gary
    #8
Share This Page
