1. SAndreasen
    Can an auto transmission ecm be used an a manual truck
    SAndreasen , Jan 1, 2024
    #1
  2. GAmes TDR MEMBER
    Yes.
    GAmes , Jan 2, 2024
    #2
  3. SAndreasen
    Thanks . I have one that’s lost wait to start and also lost the electronic throttle when you let the clutch out it’s like driving a ford it so die if you don’t give it throttle
    SAndreasen , Jan 2, 2024
    #3
  4. GAmes TDR MEMBER
    It's the PCM that is different in auto and manual transmission trucks. ECMs should be the same, I'm assuming. I saw '98 and my mind went to 12 valve trucks. Your results might differ.
    GAmes , Jan 2, 2024
    #4
    BigPapa likes this.
  5. BigPapa TDR MEMBER
    Gary is correct.
    BigPapa , Jan 2, 2024
    #5
  6. SAndreasen
    Thanks . So is the mileage stored in the ecm or pcm or speedometer?
    #6
  7. GAmes TDR MEMBER
    Isn't that information in your factory service manual?
    GAmes , Jan 3, 2024
    #7
  8. SAndreasen
    you must be referring to the one on cd that won’t work anymore
    SAndreasen , Jan 3, 2024
    #8
  9. Topzide TDR MEMBER
    @SAndreasen, Why did it stop working? Was IE based? I've had to dive into getting my thumb dive manual to work. Just have to change some settings in Microsoft edge and making it the default browser. Let us know and we might have an answer of how to get it to work.
    Topzide , Jan 3, 2024
    #9
  10. SAndreasen
    Be w an
    Im honestly not sure ? It just won’t open I'm not even sure where it is anymore I gave up on it between not opening and then pitb to try to actually find anything on it and then print anything off with trying to print the entire 7000 pages I figured I guess I got my moneys worth out of it . I thought i was being smart by getting the cd because I bought the paper copy for my 92 and the second time I opened it I had a loose leaf binder of about 9000 pages it got sent to the garage can
    SAndreasen , Jan 4, 2024
    #10
    Topzide likes this.
Loading...
Similar Threads - Ecm question Forum Date
Ecm 24 Valve Engine and Transmission (1998.5 - 2002) Jun 23, 2024
Current reputable ECM suppliers? 24 Valve Engine and Transmission (1998.5 - 2002) Jun 1, 2023
Engine/Transmission (1998.5 - 2002) ECM and FASS pump 24 Valve Engine and Transmission (1998.5 - 2002) Jan 1, 2023
Share This Page
