1. MCanning
    Hi Guys, i have a 2021 ram 2500 with 6.7 diesel and am looking for suggestions on installing the oil filter. It is easy enough to remove but a problem getting the new one up in place and started on threads, seems like it has to be done one handed, any suggestions would be appreciated, thanks
    Diesel85 likes this.
  2. Timd32 TDR MEMBER
    Tuesdak and Diesel85 like this.
  3. Tuesdak
    Fixed it for you.
    X2 on tools from Genos with the filter plug stopping the "mess" from the filter.
    You can go in through the top by removing the intake tube, but, this risks getting dirt in the intake.
    As we are quality control you might check the threads on the oil filter to make sure they are there and the proper size.
    TomBrady and Diesel85 like this.
  4. Learjet
    good videos on YouTube will explain everything. Picture is worth a thousand words.
  5. Cummins12V98 TDR MEMBER
    Forget the fancy tools and do it all from the top.
    Cummins12V98 , Jun 29, 2024 at 11:09 PM
    #5
    Tuesdak, Diesel85 and NIsaacs like this.
  6. BigPapa TDR MEMBER
    Oh, lord. Not again….
    20190511_100945.jpeg #ad
    bigceltic, KPotter, Diesel85 and 2 others like this.
  7. sag2 TDR MEMBER
    I just did mine Wednesday from the top. I removed the intake from the turbo. I have the Geno's filter plug for removing the filter, but I never prefill so it doesn't matter if I drop it a couple times while trying to get it threaded back on.
  8. Cummins12V98 TDR MEMBER
    sag2, if you wait to remove the filter after letting the oil drain a couple hours or so there is no reason to use a plug as the filter drains back.
    Cummins12V98 , Jun 30, 2024 at 11:39 AM
    #8
    Larry Willard and Diesel85 like this.
  9. Tuesdak
    If you are going through the fender you need a way to keep the filter from spilling. Although hot oil likes to splash back out of the drain container from the drain plug so for a long time I was like "why bother?" with the tools. Truck would quit dripping from the oil filter area after a few days. At least my 2018 has a funnel under the oil filter so the oil goes mostly in one place. The top side oil filter removal also allows inspection of intake boots for rubbing through.
    1.JPG #ad
    2.JPG #ad
    This does get old.
    3.JPG #ad
  10. Cummins12V98 TDR MEMBER
    I use a milk bucket that get's up close to the pan so I have zero oversplash. NEVER have I gone thru the fender. The 19 and newer trucks are so easy to do from the top.
    BD74C1C9-3E90-4C43-99C9-D89FDCA7D7E5.jpeg #ad
    Cummins12V98 , Jun 30, 2024 at 2:12 PM
    #10
  11. wyosteve TDR MEMBER
    Get the EZ Drain from Geno's and eliminate any splashing!
  12. bcbender TDR MEMBER
    LOL.... On my 2020, I don't even pop the hood open until I'm back on the ground and ready to add oil..........:cool:
    KPotter, Timd32 and Diesel85 like this.
Loading...
Similar Threads - Oil filter install Forum Date
relocate oil filter 6.7L Compacted Graphite Iron (CGI) Engine and Transmissions (2019+) Feb 25, 2024
synthetic oil 6.7L Compacted Graphite Iron (CGI) Engine and Transmissions (2019+) May 19, 2024
2022 oil temperature while towing 6.7L Compacted Graphite Iron (CGI) Engine and Transmissions (2019+) Mar 25, 2024
Share This Page
