Thread Status:
  1. SCOTTY088
    I see several different manufacturers and price ranges, what are your thoughts on the most durable and longest lasting belts on the market. My truck vin # is on the recall list for T-51 and would like to have a new belt for replacement. Thanks for your expert feedback. Scotty
    SCOTTY088 , Nov 4, 2017
    #1
  2. Cummins12V98 TDR MEMBER
    I used to buy the GoodYear Gatorback and have great life with them.
    Cummins12V98 , Nov 4, 2017
    #2
  3. Wayne M.
    Gates Green belt- Incredible.
    Wayne M. , Nov 5, 2017
    #3
  4. rynosback
    WOW, I agree with this guy again..:)
    rynosback , Nov 5, 2017
    #4
  5. Newsa
    With T51, they inspect the belt and replace if it appears to be worn?
    Or maybe I'm wrong?
    Newsa , Nov 5, 2017
    #5
  6. Cummins12V98 TDR MEMBER
    "This guy" HAAAA
    Cummins12V98 , Nov 5, 2017
    #6
  7. gsbrockman
    Nothing wrong with the OEM belt......mine went to 229k miles, and looked good when I replaced it.
    gsbrockman , Nov 5, 2017
    #7
  8. BIGNASTY
    And mine stopped that CHURP when you shut it off
    SORRY I DONT HAVE A 4TH GEN IF IT MAKES A DIFF
    BIGNASTY , Nov 5, 2017
    #8
  9. LandShark
    My thoughts are that it's a waste of money to carry a spare belt, for several reasons: First, belts on these truck typically last well over 150,000 miles. Storing a new belt for several years means you may be putting on a old belt (think tires). Belts are readily available at any auto parts place in the country, so pick up a fresh belt when you need one. Most of the time when you have a premature belt failure, you will be needing more that just a belt: water pump, tensioner, AC pump, alternator, etc.
    LandShark , Nov 6, 2017
    #9
  10. Wayne M.
    Excellent reasoning, Land Shark.
    Wayne M. , Nov 6, 2017
    #10
  11. Dick Langendorff TDR MEMBER
    My 2004 turned 252,000 miles last week. Still the original belt.
    Dick Langendorff , Nov 6, 2017
    #11
  12. Stab TDR MEMBER
    just a heads up for you dual alternator guys: The serp belt is very difficult to find at the usual auto parts stores AND dealers. I special ordered one from Carquest to have on board. Landshark has good points but, if I deem it necessary, I'll replace a new unused belt every few years!
    Stab , Nov 6, 2017
    #12
  13. jacknife
    I always keep my old one but I change them out about every year and a half. The belts wear ever so slightly. and cause slippage on the alternator you cannot hear . This will reduce your Alt out put slightly and can lead to shorter Alt life. Besides when out in the middle of nowhere and you lose a belt for whatever reason you just may need that spare . I also carry a belt diagram with me just in case I can't hook up to the internet with my phone . Also a spare water pump. Just lessons learned the hard way thru 35 yrs of truckin. Sometimes the only one to turn to is you
    jacknife , Nov 7, 2017
    #13
  14. BigPapa TDR MEMBER
    Definitely not a 4th Gen, but my '95 12V has had two belts on it in it's 500K mile life, the original and a Gates HD "Green" belt that I put on it "just because" when I swapped the engine into the '98 at 325K miles. Never had any charging issues, either, due to belt wear.
    BigPapa , Nov 7, 2017
    #14
  15. Weston TDR MEMBER
    I use the Gates green, keep spare using wife's vacuum sealer to package in. Weston, Reno, NV
    Weston , Nov 8, 2017
    #15
Loading...
Similar Threads - Serpintine Belts Forum Date
HD Belts Hard To Find 4th Generation Ram Archive (NO engine/transmission topics) Dec 12, 2021
Thread Status:
Share This Page
