Thread Status:
  1. KEN BARNES
    Has anyone replaced the turbo oil return line with a ptfe line?
    KEN BARNES , Feb 24, 2022
    #1
  2. BigPapa TDR MEMBER
    What’s max temp on it?
    And, by the way, no need for double posts.
    BigPapa , Feb 24, 2022
    #2
  3. KEN BARNES
    To BigPapa: sorry for the double post. This is new to me & don't have a clue. I'm replacing turbo on 2015 3500. Failed at 27000 miles. My question concerns the oil return line and the difficulty of replacing it. My thought is to fabricate JIC/AN fittings for the turbo end and replace the end going into the block with better insert that would have male threads to attach a flexible line to. So my question is has anyone attempted this and if yes what type of hose was used?
    thanks
    KEN BARNES , Feb 27, 2022
    #3
  4. Signal73
    Return line is rarely an issue, why do you want to replace it?
    Signal73 , Feb 27, 2022
    #4
  5. KEN BARNES
    Have you ever replaced one? If you have then you know why I'm looking for an alternative. There has to be a better idea out there someplace.
    #5
  6. Ozymandias TDR MEMBER
    Big question mark here, I did and it is straight forward. Push it into the block, bolt it to the turbo, bend it into a nice shape - finished. Couldn't be more simple than this pipe.
    Ozymandias , Feb 27, 2022
    #6
    BigPapa likes this.
  7. Signal73
    Yes, without issue. I’ve also made modified ones for twin turbo setups on previous trucks of mine. With yours At 27k that’s gotta be in pretty good shape too still, no?
    #7
  8. AH64ID TDR MEMBER
    What’s causing you the issue? Your “fix” seems much more complicated than the stock setup. No alternative needed.
    AH64ID , Feb 27, 2022
    #8
  9. BigPapa TDR MEMBER
    Yes, I’ve replaced one. As Ozy said, pretty straightforward. The tube is flexible. Much better than the rigid pipe and hose on the older engines.
    The oil coming out of a turbo can be extremely hot. I’d be worried it could melt the tubing your talking about. Now, THAT would be a mess….
    AC5EAB7D-D8F9-42FC-B635-96DE52962FB2.jpeg #ad
    BigPapa , Feb 27, 2022
    #9
    Topzide and Ozymandias like this.
Loading...
Similar Threads - turbo oil return Forum Date
Teaspoon of oil turbo inlet 4th Generation Ram Archive (NO engine/transmission topics) Apr 19, 2016
turbo problem 4th Generation Ram Archive (NO engine/transmission topics) Mar 8, 2023
2014 Ram 3500 - Turbo Pressure Going Blank 4th Generation Ram Archive (NO engine/transmission topics) Jan 28, 2023
Thread Status:
Share This Page
