1. Joseph Donnelly
    Black Market now also offers an air horn with egr ports and provision for the DIH4 grid heater.
    Joseph Donnelly , Oct 26, 2023
    #21
  2. Silver Tex
    Thank you, Mr. Donnelly,
    I went and looked at that. I’m wondering now, after adding the intake plate, air horn, and heater, if the Banks kit comes at a good price point. I have it priced at $968 for my rig, with raw coloring.
    I am wondering as well, is there benefit in the air horn upgrade if I am not putting any further upgrades on the truck? The added flow should only help and no matter how low/high the risk is in losing the bolt into the cylinder.
    Any thoughts on this? I do have a warranty but this should not affect that. It is ASE warranty and not a Chrysler.
    Thanks Joe, and All.
    Scott Solem
    Silver Tex , Oct 26, 2023
    #22
  3. cerberusiam Staff Member
    BMP horn, heater, and plate at $750 is well under Banks price, Banks seems overly proud of that offering. If you aren't adding power doubt the extra air will be a huge benefit. Just removing the stock heater is probably worth price.
    cerberusiam , Oct 27, 2023
    #23
  4. Silver Tex
    Thanks much Cerb.
    $250 is an appreciable savings for sure and the truck, stock, does everything I need it to.
    Silver Tex , Oct 27, 2023
    #24
  5. cerberusiam Staff Member
    Yup, I was looking at the Banks and kinda grimacing at the price. This looks much better and will integrate nicely to that thing we are never supposed to talk about.
    #25
    Cummins12V98, Diesel85 and Topzide like this.
  6. sag2 TDR MEMBER
    Take a look at Issue 120 pages 102-104, The Rest of the Story, for a review of the banks unit. Bottom line, special #1 fuel line required and no noticeable performance or fuel economy gain.
    sag2 , Oct 27, 2023
    #26
  7. Joseph Donnelly
    And, if you look at my review in the magazine, you will see that there may be no need to change out the intake plate which involves a lot of extra work. The Banks also requires removing the engine cover and other hassles as Stan reported. The heater is about $50 on amazon.
    Joseph Donnelly , Oct 28, 2023
    #27
  8. Silver Tex
    I recently renewed my subscription, so I don’t think I have access to any electronic version, magazine back issues and so can’t see your review or the article. I appreciate you summing up the review. I recall you (or someone) stating earlier in this thread you (they) may not remove the plate. I see there is quite a bit to remove to get the plate out. I’m actually OK with that, so if it’s not required, it can come off the truck. I haven’t fully decided what I’m going to do yet, but if I swap it all out with the Black Market stuff, I’ll relay my experience and thoughts on it. Presently, I’ll get the P2609 code resolved.
    Thank you, Joe
    Scott Solem
    Silver Tex , Oct 28, 2023
    #28
  9. cerberusiam Staff Member
    It is a pretty good assumption once the air horn is off and the condition of the grid is heater is exposed the decision to replace the intake plate becomes much easier. If at all possible, getting the intake heater upstream of the EGR has some very visible benefits. At the very least, making the heater easy to clean is a huge benefit if one keeps the emission equipment intact.
    cerberusiam , Oct 28, 2023
    #29
    Diesel85 likes this.
  10. Silver Tex
    So, if I put the horn on the heating element ends up back downstream of the EGR correct? There is just something wrong with having a soot filled intake, isn’t there?
    #30
  11. Ozymandias TDR MEMBER
    The only thing you have with a large intake is more turbo lag.
    This is not a naturally aspirated engine. Especially the VGT engines run almost always with positive pressure inside the intake, forced into the cylinders. There is no need for more room on a stock engine.
    If that horn would need a larger diameter it would have a larger diameter from the factory. It cost exactly the same to cast it an inch wider or smaller.
    Why does everyone want to be smarter then a thousand engineers in Indiana paid for to make that engine work at its best. Spending a billion Dollar to come to the point it goes into mass production.
    Ozymandias , Oct 28, 2023
    #31
    bcbender, Diesel85 and Cummins12V98 like this.
  12. cerberusiam Staff Member
    The element in the BMP manifold ends downstream of the EGR, only to negate that is the one that goes in the before in front of the valve. Not too big a deal because the rod style doesn't block the airflow like the grid and is a lot easier to remove. I agree there is something unnatural and demonic about reusing exhaust gas in an engine. Sort of like being forced to wear a mask and rebreathe exhaled air. The end results of both leave more than a little to be desired.
    #32
    Signal73 likes this.
  13. Silver Tex
    So then - If I only put the pre-throttle body heater in from BM, do I abandon all the other “junk” in place….
    Silver Tex , Oct 29, 2023
    #33
  14. cerberusiam Staff Member
    You have to move all the stock emissions equipment to the air horn if you still have it. All that moves is the heater to pre-intake position instead of in the exhaust flow.
    cerberusiam , Oct 29, 2023
    #34
  15. Silver Tex
    Yep, I get that. This is what I’m thinking I’ll install and retain the stock intake horn and its emissions equipment. I presently live in Colorado and am subject to emissions inspection/testing.
    https://blackmarketperformance.com/...-6-7-cummins-intake-air-heater-relocation-kit
    The “junk” I’m referencing is abandoning the factory grid heater plate, and therefore the bolt, in place. My factory grid heater connection is still tight and the truck has roughly 62,000 miles on it. I’ll settle this debate in my head over the next few days.
    If I swap the manifold plate, any suggestions that might make working with the #6 fuel line any easier? Recommended tools or the like? I put new injectors in my previous 5.9, but don’t really remember the challenge, except for the lifting bracket. I have watched some YouTubes as a refresher and the challenge with access comes up a few times. I don’t recall being able to get a torque wrench on that particular cylinder and that it was important to back up the tightening of line to the injector so as to not over-torque (?) the injector sleeve, but it worked out fine on the 5.9 injector swap.
    Thanks.
    Silver Tex , Oct 30, 2023
    #35
  16. cerberusiam Staff Member
    Take your time and you should be able to remove the plate and delete the heater. Not hard, just a lot of little things. You could probably just connect the power source to the stock heater and add the inline one with no noticeable difference in performance. As long as you do not get error codes coming up it should pass inspection unless they Natzify the visual inspection too much. Never know with those guys what they will come up with day to day.
    cerberusiam , Oct 30, 2023
    #36
  17. Ozymandias TDR MEMBER
    So, tampering with the grid heater is a no-no if it comes to the emissions system?
    Maybe @Turbo Terry should know that.
    Ozymandias , Oct 30, 2023
    #37
  18. cerberusiam Staff Member
    Cannot see the stock grid heater so it could be removed, no one would ever know as long as there are no codes they question. Adding the inline heater *might* trigger a response if they look close enough. If it is buried then likely it would never come up BUT the stupid emissions testing is so non-standardized it is annoying.
    #38
  19. Silver Tex
    I think I may have created some confusion. I am not deleting the heater, only upgrading/relocating from the potentially problematic grid heater (and bolt) to a probe heater, therefore retaining a heating condition within the overall system.
    I am assuming, maybe wrongfully, that if I migrate the power cable from the existing grid heater terminal to the new probe heater terminal that the new heating element will take the 200A + current and not throw a code. All other component remain in place and operable.
    upload_2023-10-30_12-33-17.png #ad
    #39
  20. Turbo Terry
    I’m not tampering with the grid heater but I might disconnect it. Certainly would reconnect it if it went back to the dealer
    Turbo Terry , Oct 30, 2023
    #40
Loading...
Similar Threads - Grid heater Forum Date
6.7L Intake Heater 6.7L Engine and Transmissions (2010-2018) Apr 23, 2024
2017 3500 - replacing heater hoses and fitting, heater core flush 6.7L Engine and Transmissions (2010-2018) Sep 14, 2023
Share This Page
