1. B.G. Smith
    06 3500, anyone ever had the fuel filter cover unscrew enough to cause it to leak?
    B.G. Smith , Oct 27, 2022
    #1
  2. Ozymandias TDR MEMBER
    No
    Ozymandias , Oct 27, 2022
    #2
    B.G. Smith likes this.
  3. Darkbloodmon TDR MEMBER
    Never
    Darkbloodmon , Oct 28, 2022
    #3
  4. Topzide TDR MEMBER
    Sounds like o-ring got nicked on the filter change. If cap was installed and tightened, it shouldn't back off at all. The o-ring not only seals but helps like a lock washer. Hope you can find out what caused it to loosen up on you.
    Topzide , Oct 28, 2022
    #4
  5. bcbender TDR MEMBER
    To add to that comment, it is possible to crack the resin cover if over tightened.
    bcbender , Oct 28, 2022
    #5
    B.G. Smith and Darkbloodmon like this.
  6. B.G. Smith
    As fine as the threads are I doubted it possible? It did start to leak and has about 10,000 miles on filter. I must have turned it 3/4 of a turn till it got tight. Haven't driven truck since. I am going to go ahead and change the filter and look at the cover real close. Thanks for the replies.
    B.G. Smith , Oct 28, 2022
    #6
  7. B.G. Smith
    Well, I changed the filter, put cap on and tightened as tight I thought was good and I could still see the "O" ring, tightened some more, looks good. Guess I was fortunate it failed at home. (It didn't fail, I just failed to tighten it right the last time.) The filter housing is kind of like the low side port on the AC as far as access. With a little more engineering they both could have been made inaccessible.
    #7
  8. User113 TDR MEMBER
    Use a torque wrench. 25 ft. lbs.
    User113 , Nov 1, 2022
    #8
  9. bcbender TDR MEMBER
    I noticed the new 6.7 has the torque spec moulded onto the lid...
    bcbender , Nov 1, 2022
    #9
    Darkbloodmon and B.G. Smith like this.
  10. Ozymandias TDR MEMBER
    I never ever torque that lid, just snug and it's fine.
    Ozymandias , Nov 1, 2022
    #10
Loading...
Similar Threads - Stock fuel filter Forum Date
'05 Fuel fliter change, stock 5.9L Engine and Transmissions (2003-2007) Jan 27, 2024
stock fuel pressure 5.9L Engine and Transmissions (2003-2007) Dec 5, 2019
2005 stock Air Cleaner parts 5.9L Engine and Transmissions (2003-2007) May 12, 2023
Share This Page
