Thread Status:
  1. CAROLINA CUMMINS
    Hi,
    Those running 295's and AlfaOBD. What circumference did you use? I calculated it to be 2735 mm for a 34.3" tire.
    CAROLINA CUMMINS , Sep 5, 2020
    #1
  2. AH64ID TDR MEMBER
    What brand tire?
    Many tire manufacturers publish rev/mile data and that’s a great starting point, but it will likely take a few adjustments to get correct.
    AH64ID , Sep 5, 2020
    #2
    Wiredawg likes this.
  3. CAROLINA CUMMINS
    Falken Wildpeak AT3W 295/70R18
    Manufacturer lists it at 34.3" so then I had to convert to circumference in inches then millimeters.
    I assumed AlfaOBD would just let you pick size but no 295's are listed. Mostly stock sizes looks like.
    #3
  4. AH64ID TDR MEMBER
    Falken lists that size at 609 rev/mile, which is 33.1”. I’d start there.
    #4
    Wiredawg and CAROLINA CUMMINS like this.
  5. Ozymandias TDR MEMBER
    I always went with the revs/m from the spec sheet of the manufacturer.
    The circumference is just a ballpark number.
    Ozymandias , Sep 5, 2020
    #5
    Wiredawg and AH64ID like this.
  6. CAROLINA CUMMINS
    Only options I saw on AlfaOBD was a list of sizes and even tire brands. Larger sizes aren't on there. Then other option is circumference in millimeters? Did I miss another option?
    #6
  7. AH64ID TDR MEMBER
    Just convert inches to mm.
    #7
  8. CAROLINA CUMMINS
    609 rev/mile - 33.1" worked out to 2641 mm so I'll try that for a bit. Thanks
    #8
  9. Ozymandias TDR MEMBER
    Isn't it in the ABS unit where you can dial in the Revs?
    #9
  10. CAROLINA CUMMINS
    In the BCM on mine. Screenshot_20200905-233952_AlfaOBD.jpg #ad
    Screenshot_20200905-234003_AlfaOBD.jpg #ad
    Screenshot_20200905-234010_AlfaOBD.jpg #ad
    Screenshot_20200905-234108_AlfaOBD.jpg #ad
    #10
    TimothyLong, Wiredawg and Ozymandias like this.
Loading...
Similar Threads - AlfaOBD 295's Forum Date
Alfaobd actuator question 4th Generation Ram Archive (NO engine/transmission topics) Jun 14, 2022
Daytime Running Lights (DRL) - AlfaOBD Help Needed 4th Generation Ram Archive (NO engine/transmission topics) Dec 6, 2021
Stationary Desoot with AlfaOBD 4th Generation Ram Archive (NO engine/transmission topics) Sep 7, 2020
Thread Status:
Share This Page
